当前位置:首页秒懂好车视频
无惧冰雪 长安猎手零下20度雪林穿越
2024-02-05 27.58万播放 30秒懂车车评人:李鹏飞
2978
00:31乌兰布统冰雪林海穿越
01:03长安猎手皮卡介绍
As the world's first super-increased Pika, it has the advantage of power, long endurance, and external electricity., It has become known as the intermediator of the oil and gas Pika.
01:53动力与四驱系统测试
We all know that there are two points to the test of the car in low-intensity ice conditions., The first is whether the power output is strong enough., The second is whether the four-wheel system is stable enough., In addition, the road surface situation is complicated and variable., So this will bring a lot of challenges to the intervention and work logic of the four-wheel system of the car., However, after a period of time, I found that the whole set of power output of the super-increased Pika is relatively reliable in extreme conditions.
02:31增程器与电池性能
Its maximum power can be up to 200,000 watts., The maximum torque can be up to 470 nm., The torque at the end of the wheel can even reach 5,000 nm., In addition, the speed of the electric motor is much faster., So the Pika model with this body can do 0.4 seconds of rapid response., Of course, as a qualified hunter, not only does it have a powerful power reserve,, but also a four-wheel drive that constantly transports snow., In addition, it also has a large heart., Here I have to mention that the long-distance hunter is equipped with a 20T Lanjing booster., Its attack rate can reach 140,000 watts., The battery charge capacity is below 8%, and it can still be extremely powerful., Simply put, it is like a super-large charge., Even in the case of continuous climbing and long-distance high speed,, it can actually provide the motor with continuous energy output and ensure that the power is always full.
03:49越野能力展示
First of all, the long-distance hunter has a set of smart electronic four-wheel drive structures at the top of the industry., It not only brings a full-time and full-time pure electricity price,, but also allows you to freely switch between two-wheel drive and four-wheel drive., It can be said that such a good second-to-second switch can only be achieved by electric four-wheel drive., In addition, the front and rear speed sensors can also quickly intelligently assign the drive force of the wheel,, and increase the ability to decelerate., For example, we are currently driving on this snow-capped intersection road., As long as there is a large slope on one side of the wheel, the car will be instantly locked., Then, more power is assigned to other wheels with load capacity,, making the car more stable, making the passing performance more reliable and efficient., That is also due to such a complete set of four-wheel drive systems and front and rear speed sensors
04:47能耗表现与续航测试
we actually bought a small egg in advance., Before starting, I have cleaned the small machine of the car and adjusted the air conditioner to 26 degrees automatic., At present, it has been driving for about 50 kilometers., At this time, the performance consumption is only 70 kilometers., Its overall endurance resistance can reach about 70%., If you consider the extreme environment and high load-bearing cross-country road conditions,, the long-distance hunter's energy consumption control is really good enough., Especially compared to those pure Pica cars, it can really completely get rid of endurance anxiety.
05:36户外体验与外放电功能
As for the appearance, we might as well take a look at the long-distance hunter., In addition to helping us climb mountains and mountains,, it can also provide high-quality outdoor experiences., Pica lovers are usually big lifeguards., They are even more attentive to the Pica wild boar., The external power function of the long-distance hunter can help you enjoy the long-distance hunting., It has a 227-degree storage capacity and supports 2,000 watts of electricity., The longest use is 100 hours., In addition, the 3.3 kilowatt large-power portable power panel, At this time, the long-distance hunter is like a large outdoor power source., Whether it's hot pot or barbecue,, eat as long as you want.
07:46总结与体验反馈
After a day of experience, it is not difficult to find that long-range hunters can bring a very stable and reliable use experience even in a low temperature environment below 20 degrees Celsius., Thank you., It's very convenient., Whether it's the power, external power, battery safety, and durability, etc., they all perform very well., Especially compared to traditional Pica cars, it's really too convenient., It not only eliminates the problem of oil refueling in winter, but also the problem of pure Pica that doesn't have a battery., The problem of battery power and battery life., It can also rescue people., It can help people go out and fix a car., What does it really mean?, It means one car is more useful., Okay, that's all for this issue., See you next time., Bye-bye., Bye-bye., Bye-bye., Bye-bye.
  • 00:31乌兰布统冰雪林海穿越
  • 01:03长安猎手皮卡介绍
  • 01:53动力与四驱系统测试
  • 02:31增程器与电池性能
  • 03:49越野能力展示
  • 04:47能耗表现与续航测试
  • 05:36户外体验与外放电功能
  • 07:46总结与体验反馈
